Lamp Socket Accessory Settings - Please Update Camera Firmware (Bug?)
Hello everyone— I need a bit of help! :sweat_smile:
I just set up a new V3 cam with the Lamp Socket— everything is working fine EXCEPT the actual socket settings… I.e. no way to turn the bulb off, etc.
When I go into the cam’s Settings>Accessories>Lamp Socket it keeps saying “Please update your camera firmware to the newest version.”
So then when I check to my cam’s firmware settings it says that I am all up to date (version 4.36.3.19.) I’ve tried resetting, turning off and on, etc nothing is working!
I’ve even tried setting up a shortcut rule as a workaround and nothing… The bulb in the socket continues to stay on.
I am running the Android app on my phone (no beta, up to date there too.)
Please help! :pleading_face::pray:t2:
Hmm, the latest v3 firmware is 4.36.9.129. This is not the version your on? Are you able to updated through account > firmware updates?
If not, try clearing your app cache in account > app settings. Then force close the app and see if an update is prompted.
If not, you can try manually flashing the latest firmware with:
Can you double check your Android app version under Account > About, having an old version could affect that.
I have the exact same issue as OP and am running the latest version of the android app V2.33.1 (162)
What firmware is your camera on?
exactly the same at OP - (version 4.36.3.19.). No pathway to updating my firmware recognizes a need for an update - clearing the cache doesn’t help, I’ve combed the other threads and nothing has worked. All the wiring is per the directions, using the usb provided in the socket package.
There are a few threads where the firmware is stuck on that version.
I would try manually flashing, but @WyzeJasonJ this seems to be happening more…
Thanks for the info. We did locate and fix this issue. Now your V3 should be able to upgrade to the 9.139 firmware.
Literally just did it a few mins ago and everything works perfectly now. Thanks!!
At Firmware 4.X.139, clear app cache, power cycled waiting >20 seconds. Still getting: “Please update your camera firmware to the newest version.”
All - I left this camera and socket powered overnight and this morning, I was prompted to upgrade the firmware. Also, I am unsure if I made an error, but the WyzeCam v3 was firmware upgraded to 4.X.139 this morning. Yes, I thought it was at .139 prior to this. Unsure if I am at fault or otherwise.
With the .139 firmware, the socket is functioning. I even was able to upgrade the firmware on the socket. So, I will keep fingers crossed all keeps going well.
