I just installed my new bulb cam and I am shocked to see that you cannot move it using the app or any other platform. It has to be adjusted manually and then it can’t move around to view the area like all of the other cameras I’ve installed outside. This would be the most difficult one to manually adjust so I do not understand why this feature was left out. I can’t believe I didn’t even notice that before I bought it.
Correct, it is not a motorized or “pan tilt” cam. Where did you see that it was? It is meant to be a “set and forget”.
I got it on Amazon and I didn’t see it advertised that way, I saw “extend, rotate, tilt” and thought it was the same as the WYZE Cam Pan v3 that I have. It looks so much like it, I just assumed it was the same. - -
