I read by wyze that the cable power connection isn’t weather resistant (needs the rubber cap to seal it). So running it with a power cable in would void the warranty. Seems to me like this could have solved by including another rubber cap to fit over the cable or another cable with a built in seal. A commenter posted that keeping it plugged in would overheat the batteries.
Check this post out: Add More Device Triggers for Wyze Rules - #31 by ThomM
That isn’t very likely. Batteries have to be equipped with charge controller circuits to control overcharging.
If they said not to use it while it charges, I didn’t see that. What I did take note of is that it isn’t meant to be plugged in all the time as it is meant to or is “expecting” (something like that) to be powered by its internal batteries.
Keeping it plugged in continuously will cook the batteries.
I am made of questions. What kind of a bug puts out enough body heat to trigger an infrared sensor? When did the V2 get an infrared sensor?
Maybe. Although we might be using different definitions of “cook,” I’d like to hear that from Wyze. I have an iPad that is plugged in continually (for well over a year now) and that hasn’t “cooked.”
No it won’t. Batteries have charge controllers that won’t let them be overcharged.
Well, yeah, but your iPad also wasn’t $39.
/Antney
Charge controllers are less that a dollar.
Yea… but at less than $50, you just buy a new camera…
Will RTSP firmware be available?
RTSP means continuous recording.
I can say it will never happen. You will charge your battery daily?
Plug them into a Wyze smart switch (or alternative). Leave Off normally. Turn On from your phone every few months to charge up, then turn Off again. Roundabout way to have permanently plugged in without shortening your batteries lifespan…![]()
Not an issue of “cooking” batteries BUT heat is the enemy. Which comes with constant charging. Even high end devices will do better if not left constantly charging. Left my last phone always plugged in and lasted 3 years but on replacement they found a clear bulge in the battery. The expansion could have destroyed my device. Repair tech strongly advised against this and recommended charging only to 80% for best chance of long life. Charge cycles cause oxides on the electrode over time that will shorten battery life. Generally happens mostly above 80% charge from what I understand. Reason a lot of battery chemistry research is focused on this very issue particularly for EV’s…
It’s questionable at this point if these batteries could or would be worth replacing so would follow Wyze’s recommendations to get the longest life out of these cameras…
Any chance your Canadian cousins can purchase some.? WYZE can ship them via USPS to Canada. It’s easy!
Steve W
The camera is essentially pointless if it can’t be plugged in and used for continuous recording.
The battery is a nice touch for when the power goes out if it can continue to record motion events to the sd card and/or be accessed via a direct wifi connection from a nearby device.
well, the people complained do not care the life of battery much, the value of battery like a few bucks.
we complained
(1) no wearterproof when plugin
(2) no continous recording (though we can schedule 3 different continuous recordings to cover a full day and only missing 15 minutes, my guess)
why we complain?
because we were expecting BOTH battery AND powered version of wcos but end up w/ battery only practically.
I have the same problem in the UK - happy to pre-order but how??
Why not just use the regular cameras then? Been using my Wyze Pan outside with a case for a year with absolutely not issues.
I currently am using 3 regular wyze camera’s outside, with the covers that look like little birdhouses.
The only problems I have are A) spiderwebs B) occasional things getting on lens C) wasps keep triggering person detection.
I’ve been running those three for over a year and a half, through two snowy winters. So yes, I know regular wyze cams can be used outside.
But, I’ve been waiting for the outdoor camera for a year and a half so I can put up two more cameras. Thus, I am disappointed because
A) I waited a year and a half due to the “almost there” news
B) The outdoor cam costs the same as I will pay for my regular wyze with birdhouse cover.
I also feel a bit betrayed because
A) In one of their question and answer sessions about the outdoor cam, they said you would be able to plug it in. I think that was about a year ago.
B) If they had said a year ago that they were developing a battery only wyze outdoor cam, I wouldn’t have gotten my hopes up, and just bought the others.
