Issues and then corrects itself?
Why is it that I’ll get codes that state the Authorizations failed Key expired and assorted codes like 10003, and many say to reboot the devices, reset camera, (including wifi, base, cameras, my phone, you name it) and before I get even half of that done because I’ll have to go through many steps and I just give up before I even get started. the next morning when I go to check on both the hardwired and battery wifi cameras, everything works again. ???
like are there ghosts in my devices? so temperamental these are!
Just wondering if anyone else has had this problem where after hours of trouble, these suddenly fix themselves.
The symptoms that you are describing indicate WiFi channel congestion. I had similar issues long time ago, new modern router fixed my problems.
