All I would like to do is have a closet light turn on when I open the door and off when it closes.
Currently the only way I know of is using IFTTT, but it is fairly simple
Really? They literally marketed the bulbs as being able to do exactly this with the Wyze Sense
Should be able to do it through the shortcuts
I stand corrected, you are right, it is accessible through shortcuts
If you go into shortcuts you can add a shortcut to do what you are wanting to do
Thank you all for the help, I really appreciate it.
Not a problem thats what the forums are for
