I have a closet bulb that goes on and off with a door sensor. Also have a porch light that goes on and off with a motion sensor. They both work perfectly. But when I look at the shortcut history, it says failed every time. The only reason I found this was because I wanted to test some other sensors further out on the property, and was going to use the logs for testing. Anyone else notice this? I have tried deleting and installing the shortcuts, cleaning out the logs and cache, clearing the cache from my phone, and everything is updated to the latest versions. Thank you in advance . . .
Yes I am getting similar issues with shortcut logs. Thing is sometimes they truly did fail sometimes not.
I am having some of the same , I also saw people on Reddit and FB mentioning it
