Is the RTSP stream toxic?
Noticed decreased performance after adding 2 more V2 cams to existing 3 I have defined in iSpy. Immediately noticed decreased performance. While it is normal for frame-rates to decrease as more cameras come into the pool, it became worrisome when the Windows 7 PC began to freeze randomly.
Haven’t been able to establish any pattern, but the PC would be found frozen daily for almost a week. Removed all Wyze cams from the iSpy configuration and all is well again.
Is something about the Wyze RTSP stream toxic enough to cause a PC to freeze? (There is nothing in Windows Event Logs to indicate anything related).
Going to install the same setup on another PC and see if the behavior is the same.
“Toxic.” Technical term? :wink:
If it brings a computer to its knees, then yes. At least its easier to understand than some of the tech jargon :grinning:
