IOS is "Nothing to see here" ✅ Android is OK to view Events recording
:white_check_mark: In iPhone-7 IOS 13.6 I can not see Events recording as only shows “Nothing to see here” but I still can see live in which Cam V2 I select. I also update the Wyze App in IOS but still same problem “Nothing to see here”
:white_check_mark: In my old Android Nexus 6.0.1 I still can view all Events recording plus live as the Wyze V2 supposed to be like before either in IOS or Android like it was years ago ➜ ➤ Other members in the family with their iPhone-X or 11 difference than my iPhone-7 have no problem to view recording Events. ➜ ➤I ask all WYZE Guru here or from WYZE.COM for help if that possible why I can not view the Events recording in IOS ?. ➜ ➤ Thank you you all. :white_check_mark: PS: May iPhone-7 for Wyze-App is not compatible anymore ?
I’m having the same issue. No events after 3pm yesterday. I have an iPhone 11. I don’t think it has anything to do with your phone. I’m at work, but, I’m going to unplug my cams and plug them back in when I get home.
check your event filter at the top right of the Screen ~looks like a funnel. Be sure you dont have anything set or that’s all you will see. If you pick a cam with no events that’s the message you get.
Yes Sir ! :white_check_mark:
At the looks like a funnel I unchecked all Cams plus uncheck mark 'SEEN - Person", now I can view the Events Recording motion as soon as clicking the “Show results”
Thank you so much.
PS: Ask , and it shall be given you ; seek, and ye. shall find; knock, and it shall be opened unto you : 8 For every one that asketh receiveth; and he that seeketh. findeth; and to him that knocketh it shall be opened.
I fixed mine problem.
Read tomp Forum Maven replied → tompForum Maven
Thanks to tomp Forum Maven again :grinning:
None of mine were checked. Hopefully a reboot will fix.
If I not uncheck the bottom one saying 'SEEN - Person", or whatever you have in your iPhone there, person or motion or else, I can not view the events recording but as soon as I uncheck mine at the most bottom saying 'SEEN - Person", it works right away
None of that. No. That’s basic. But, thank you.
