iOS 23 Broke my Wyze
Any one else having any issues with Wyze since IoS 26 Release I’ve lost all connection to my Wyze devices my home address was removed all integration and any automation has been vaporized and this is just Wyze not to mention so many other apps and product issues.
Have you tried to downgrade from IOS 26 back to IOS 18?
Apple has stopped signing iOS 18.6.2 on Sept 22 (1 week after iOS 26 release date). You can no longer downgrade if you are on iOS 26. I just updated to iOS 18.7 via OTA and avoided upgrading iOS 26 due to the numerous reports of battery drain, stutter and lag especially on older phones. I will eventually upgrade to it on the next upgrade cycle when they fix more bugs and improve the UI.
I haven’t had any issues with iOS 26 on iPhone 11. Battery life is the same if not a bit better and I left transparency on. Last night I updated to iOS 26.0.1 and no issues, knock on wood.
Weird, they usually have longer window for downgrading. Probably issue reports must’ve been lower than they expected.
I have a similar issue. Since the last update (Wyze and iOS), my automation to trigger my lights from the motions sense V2 no longer works. I have tried all online troubleshooting (deleting app, clearing cache, rebuilding Automations, etc, does no good at all. I can manual switch lights on and off, but cannot trigger change by motion detection/clear.
