Introducing Wyze Window Bird Cam and Bird Watch - 11/24/2026
Introducing Wyze Window Bird Cam and Bird Watch, a new way to bring backyard birdwatching right to your window. The wired, window-mounted camera pairs with an outdoor feeder to bring you up-close HD views, with free bird detection, bird-arrival notifications, local microSD recording, and clip sharing. No subscription is required for these core features.
Want to discover even more? Bird Watch adds bird species identification, bird facts, visit logs, 60 days of cloud storage, full-length event recordings, and monthly Bird Highlights recaps. Set it up at your window and see who stops by.
Learn More:
https://www.wyze.com/products/wyze-window-bird-cam
Bird Watch is not available for other cam’s? i.e. the BCP for the birdhouse?
I’m definitely hoping this will be included in Cam Plus Pro - AI Unlimited - Platinum Premier Membership (+) … adding another add-on to the subscription would seem a bit much.
It is only available on this camera because it is designed specifically to utilize this cameras special focal length, which is optimized for viewing birds up close.
I see it includes a hummingbird feeder right next to the seed tray. I can tell you from experience that if there is birdseed in the tray, hummers will not stop for a drink. That will create too much activity for the hummingbirds.
Any plans for other cameras?
I still think they should’ve called the bird detection and species ID Cheep! :zany_face:
I was literally going to re-post that… they ignored your “perfect” marketing name.
Hummingbirds get territorial over feeder but it’s pretty easy to customize. I can remove the nectar feeder to feed seed birds only or feed hummingbirds only.
They don’t have a problem with mine (beta tester). Before they left for the winter the humming birds were the most frequent visitors. Also had finches, chickadee’s, wood peckers, and blue jays.
