Infrared reflecting in window
Does anyone have any advice on how to make it so your cameras can look out a window at night? The problem is the lens reflects a light into the window turning it into a mirror so you cant see outside with the infrared. Ideas?
Basically you turn Night Vision to On or Auto, and turn the IR lights to OFF
Single Cam View β†’ Settings (gear) β†’ Advanced Settings β†’ Night Vision Mode β†’ Auto
Single Cam View β†’ Settings (gear) β†’ Advanced Settings β†’ Night Vision IR Lights β†’ slide to OFF
If you have problems with a white β€œghost ring” reflection of the camera in double pane glass, just black out the front of the camera around the lens with a large Sharpie marker.
