I want to connect to thee wyze light bulb on two separate phone
I have connected to the wyze light bulb but my wife cannot connect. Once she connect then I am automatically logged out
It is possible that two phones be connected to the wyze light bulb at the same time
Welcome to the Forum, @tunji.fagbemi! :wave:
I’m not sure what you mean by “connect”, but I think you essentially have two choices:
  1. Add the Wyze device to your account and then share it to your wife’s Wyze account (navigate to  Account âžś Sharing in the app). She should be able to accept the invitation in her app. (Alternatively, she could set up the device and share with you.)
  2. Some spouses just share the same Wyze account, so you would both log into the Wyze app on your individual phones using the same credentials (e-mail and password).
I think the first method makes the most sense from an account security standpoint, but because of some limitations with shared-user access, I understand why people use the second method in some situations.
Also, I wonder which Wyze product(s) you’re actually using. Your topic title and post indicate Wyze Bulb, but you created the topic in the Cameras category with the tag for Bulb Cam. If you can provide some clarification about this, then we can make sure your topic is classified for the best visibility for your issue.
