I have the wyze cam og and pay the 1.99 subscription and called them on the phone regarding recordings
yes it was. and i had sound deteciton sensitivty set to 80 between low and high, which the lady on the phone told me was what i needed for it to be able to pick up sonud more often. this was av ery loud event, theres no way it didnt pick anything up. id always notice when watching the camera live i could hear the sound, yet all of the mp4 files have 0 sound
Try using VLC player. I, as well as others have had good luck with that video player and it decoding Wyze audio.
the sd card was removed, and theres a clip that says 5m. but when i download the clip, or click into it, its not nearly 5m. what the hell is going on here?it says person 5m and yet clicking into it , its 00:22 seconds. downloading it also doesnt give me the 5m version. can this be explained?
also, in this scenario, the camera was unplugged, and the camera looks as its own cable where its plugged into the wall outlet, but im wondering if such an event can even be captured or would the timing of the unplug make the video not be able to be saved down in time?
I am guessing your still looking in the app for the footage? When you remove the card from the camera, place it into a computer, then use whatever file directory viewer you use to surf to the removable drive that popped up and look for the one minute videos there.
If the camera is unplugged when it is recording an event, then the event probably won’t get or have time to be uploaded.
I have the same problem as thisAppDoesntWork with multiple cameras on different networks. When I installed and initially used them, no problem. Within the past few months, all of them are giving me issues with downloading, playing and recording video from the SD card. I have OG and earlier version cameras. Live stream is good. What are possible causes for this. SHould I just trash all of these and start over with another camera? This is specifically the reason I got the cameras.
