Hub not appearing in the monitoring tab
Just purchased the the home monitoring kit and finished setting up the hub + sensors.
However when I go to the “monitoring” tab on the app, only my cameras are showing up in this section. I can’t seem to add the hub + sensors.
Anyone know why this is happening?
If you subscribed to HMS then you will see the sensors. I believe that by have Cam Unlimited you will be able to utilize the Cameras and Cam Unlimited Pro will allow for the sensors. Cam Unlimited Pro has not been released yet
However, by having the Hub, you can use the sensors as with other devices and setup Automations based on them
Here is a link to see a comparison of Plans
