How to setup rule to Alert me if m'y device stop Working after the plug?
Hello, is possible to create rule in Wise apps in order to Alert me if the device connected (water pump) on my plug Outlet stop Working. Explanation. I have a water pump that Will Nevers do to stop. And if the waterpump stop Working i Will have big problem, so, i need wyze rule setup in order to notify me if Power consomtion fall. This is can alert me if pump stop Working. And i Will can change pump shorty delay
No.
Terse. :laughing:
Hum…ok . So the wyze alerts are very limited. Thanks for the precise answer.
terse@amazon return :ok_hand:
If you want it to do exactly what you describe, the answer is valid, and I wasn’t laughing at your expense, I’m just a little over-jolly sometimes. Maybe.
Anyway, we’re both just fellow customers with a fair amount of experience who help out a bit here.
If you’re interested in being notified if your pump stops pumping there may be other ways of achieving that with a cam or sensor etc and a workaround/contraption kind of setup.
Can you post photos of your situation to help out? Is there something on the pump itself like a status light that is ON when pumping and OFF when/if it stops? Stuff like that. :slight_smile:
Welcome to the Forum @ghislainmasson
Welcome to the Wyze User Community Forum @ghislainmasson! :man_raising_hand:
It is going to take some research online to determine which brands will send Push Notification Alerts for changes \ loss in power consumption, but what you are looking for is a Smart Plug with active Energy Monitoring.
Welcome to the Wyze community ghislainmasson. Wyze currently does not sell any products that trigger and notify based on current draw. There are however many other solutions in topics on this forum submitted by community members. If you have a Wyze Home Monitoring System (HMS), you can use a leak sensor with probe to accomplish your goal. Here is another solution with plenty of other product references in the replies:
