How To Save Video To Desktop Via Web Browser
I see no options to save a video to my desktop computer via a web browser. I can view all of the videos. Am I missing something? How do I select videos to save?
Not possible via web view, but there are 3rd party web video capture tools that can do it.
The wyze app supports it, easiest to just do it there. You can both record the live view and download event videos in the app.
That’s simply unbelievable to me, but okay. I don’t have time to dwell on it. I’ve “downloaded” videos on my iPhone. Where do they go? I cannot find them in my “Files”.
I don’t use an iphone but on my android they go right into the gallery (in a subfolder called like Wyze but my gallery doesn’t care about that). There is also a gallery built into the wyze app which basically shows you the same thing/files, which you use is just a matter of preference, I like to use the gallery I’m used to.
On Android, the “My Files” app lists the recently created files. It always lists the downloaded files. I never try to memorize where Wyze keeps them. I check the recent-files-list, and move what I need.
What do you see in Cam Pan v3’s “Album”? If you swipe right-to-left on the icon bar below the live view pane on Cam Pan v3’s Live Stream screen, then Album should be third-from-last on the list, between Pan Scan and Timelapse. I don’t know what app iOS uses as a general file manager, but you should see saved event videos for that camera there.
The downloaded videos from Wyze app usually go into the Photos app under Videos unless you have selected a different path.
Thank you.
Oh iPhone they go into your photo gallery (Photos app).
