+1 from me. I see everyone saying basically accurate things from different perspectives.
Since I was asked, Iâll try to add some clarification of my own even though I think itâs mostly worked out already.
Cam Plus is not needed for GENERAL sound notifications, only for the specific AI sounds (Crying, Barking, Meowing, Talking Gunshot, Glass Breaking being labeled separately with separate notifications for only those things instead of just âANY SOUNDâ).
But you are correct that Wyze should clear up the ambiguity with an improved interface to show whatâs free vs premium.
They should also change the wording from saying âOther Soundâ to say âANY Soundâ or âAll Soundâ to clarify that it includes the AI sounds too, but wonât distinguish between what type of sound it heard.
One thing that really affects sound events and notifications though, is that sound can only trigger an event once every 5 minutes and it is limited to a 12 second event. These sound limits are even in place for people paying for cam plus. However, if an event was triggered by motion, then the AI will analyze the sound during that entire motion event and not limit it to 12 seconds.
In other words, if someone is behind the camera and starts talking, but the camera doesnât see them, it will trigger and record for 12 seconds and send an alert. However, if it had sound triggered anytime in the last 5 minutes, and now new sound is made, it will ignore that sound and not tell anyone about it until a full 5 minutes passes, then if it hears another sound, it will trigger a new 12 second event and alert. A lot of alerts get missed this way. I reported this issue to Wyze some time ago, that even cam plus subscribers are subjected to a sound cooldown, just not a motion cooldown rate limit.
In some cases this can explain why a person can stand behind the camera and yell and not get a notification, because it already detected a sound event in the last 5 minutes. samsam can better verify this by going to the events tab and using a filter to select the specific camera they are testing and then sort it to only show events with a âSoundâ detected. (I think free accounts should be able to sort by sound events still). If any show up, then you can be sure sound events are actually processing. If one happened within 5 minutes of your testing of yelling at the camera, then that would explain why you didnât get a new notification. But if it shows an event and you just didnât get a notification for it, then there is a separate issue entirely and we need to figure out why notifications arenât coming through (check everything @Crease posted)
Yes, if a person doesnât have a subscription then ALL sounds get processed as âOther Soundâ BUT if a person has Cam Plus, then Cam Plus will give priority to the specific subcategory of sound detected before just labeling it âOther Soundâ like fmills1d is accurately explaining has been their experience while using it with the subscription.
Here is the how that is supposed to work, and they sometimes have a bug with it:
If you select âAll Eventsâ then go to custom detections, you have the option to select AI events and âOther Motionâ (AKA âALL Motionâ) and âOther Soundsâ (AKA âAll soundsâ). And in the cloud events tab, it will also show you events that didnât have an AI detection in them.
If you select âSmart Detection Eventsâ then in theory (not always in practice) it should disable the âOther Motionâ and âOther Soundâ notifications and labels and automatically delete (or hide) all cloud events that donât have an AI detection in them. This is intended to keep your events tab clean and only show you events that have relevant AI detections in them.
Sometimes there is a glitch and selecting âSmart Detectionsâ only hides the option to turn on or off notifications for âOther Motionâ or âOther Soundâ but will continue to send you notifications for those even though it is hiding the events for those from you. In that case the only way to overcome that accidental but annoying bug is to temporarily switch back from âSmart Detectionsâ to âAll Eventsâ so the notification option will show up for you again, then go to customize and manually toggle off the notification for âOther Motionâ or âOther Soundâ and then you can go switch back to âSmart Eventsâ and everything will go as intended (only get notifications for AI detections and only see AI events in the cloud events tab).
Hopefully they fixed that bug though. I havenât seen anyone reporting it since I reported it to some employees a while ago. ![]()
Sorry, I know thatâs a little confusing.
TL;DR: I think there was just a misunderstanding and everyone was saying basically correct things from a different point of view of free vs premium, and it looks like samsam got the issue resolved.
(sorry for the late responseâŚI have a ton going on this weekend)
