Is there a way to free up space/delete all videos on my SD card within the app?
Thank you!
Thank you!
In the current beta app, you can format the card to reset it to empty.
You don’t need to delete videos off your SD card to free up space. The app will automatically delete old videos to make room for the new ones.
But like RickO said, only the beta version has a way to format the SD card. And formatting erases everything
