How To Delete 12 Second Events At Once?
Have a wyzecam 2.
Is there a way to do since without having to open each 12 second event video and having to manually delete each video?
I like to know is there a way to load all the 12 second events and then you check mark any or all of the ones you want deleted at once? How would you do this?
On your phone/tablet, at Wyze app Home page, tap the Events icon at the bottom > use one fingertip to swipe up and scroll the list of events up. Keep doing that until you reach the bottom of the list. Now put one fingertip on an event near the bottom and drag it up and hold it until you see a spinning circle at the bottom. That will load even more events. Keep doing that until you reach the start of the day or oldest event for the day. Tap the edit (pencil) icon in the upper right corner. Tap “Select All” then tap “Delete” at the bottom.
There is a treasure-trove of good, helpful info on the Support site. But some of it is a little out-of-date and may not exactly align with your app version.
Wyze App & Account
Wyze App Getting Started
Not really to my knowledge. No convenient way at least.
In theory it might delete them all if you remove the camera from Cam Plus lite wait a bit then add it back on. I haven’t verified that though. It might also work to delete the camera from the app then add it back on. I haven’t tried that either but I imagine those are workarounds I’d try if I needed to quickly “hide” all events from someone.
All Wyze Cloud videos get automatically deleted after 14 days (whether you like it or not).
Just curious, what is your reason for wanting to manually delete all Cloud videos before they become 14 days old?
