How do you remove the button battery from the water leak sensor? I unscrewed the back cover but I could not figure out how to remove the button battery. I tried pressing the button battery on different areas but it did not pop up or slide up. I checked the WYZE help center and was unable to find out how to do this.
Just smack the open battery side onto the palm of your hand. Should pop out.
