I have a Cam V2 schedule enabled to mute notifications between 10am and 10pm. But sometimes I want to receive notifications during that time slot so I set up a shortcut to unmute all notifications. How do I re-enable the existing schedule (mute during those hours) and/or also deactivate the rule (unmute notifications) that I enabled via the shortcut? Thanks in advance.
Not sure I 100% follow. But if you wanted to disable the notifications during the scheduled hours because you enabled it, you would need to create another shortcut to disable notifications.
However, the next morning at 10am, the rule will run and disable notifications,
