How do I obain a Wyze Base Station in order to connect my indoor/outdoor Wize Cam3?
I purchased a Indoor/Outdoor Wyze Cam v3 and I understand it requires a Base Station. I don['t see them in the online Store, so I’m trying to find out where I can purchase one. Any help will be gratefully appreciated.
Thanks,
Jerry Bacon
The V3 Cam uses 2.4Ghz wifi not a base station, so as long as you have wifi you are good.
Correct. It is the different “Wyze Cam Outdoor” model that uses a battery and requires and ships with a base station.
The V3 doesn’t need it.
