How can I add device battery cam pro?
I want to buy the wyze battery camera pro. But the old wyze app on my old cell doesnt have that camera under add device. And my current cell the samsung android a13 cant download the current wyze app.
So do I have to upgrade my current cell? Will the current wyze app support the samsung android a16 that is a 5g 128gb I saw for sale at bestbuy? Or is there a way to add the camera from my old wyze app on my old cell the samsung j7?
Samsung A16, I believe is running a 32-bit version of android. App version 2.5 is the latest you can install. Ask @StevenA if the battery cam pro is recognized by that version. Installing an older app version is more involved than just updating via Google Play.
To install the latest app, you need an android phone that runs the 64-bit version of android; I believe all Samsung A-series phones run 32-bits.
I am on App version 2.50, but only use Cam V3 cameras.
You press “+” to add cameras and look over the list. It should list all the cameras recognized by v2.50. You can cancel the “Add” after that.
Battery Cam Pro can be added in App 2.50.
