I do not have the physical keypad for the Home Monitoring system. I’ve been using the app only. Since I work from home most days I’d like the monitoring to stay on “I’m Home” First of all, every time I press the “I’m Home” button, it spins and spins and will finally give me the error “Mode switch failure” every time. I have to arm the system with the “Away” button first and then switch over to “I’m Home”, then it seems to work. Secondly, I assumed it would stay in whatever mode I left it in until I switch modes or press “Disarmed”. It doesn’t! If I check it a day or 2 later it shows “Disarmed”. I’ve looked for settings I may have inadvertently set for a timer or on/off time but haven’t found anything. Is this how it’s supposed to work??
Related topics
Topic | Replies | Views | Activity | |
Home Monitoring Keypad Home Button Does Nothing | 5 | 485 | July 24, 2021 | |
Wyze Home Monitoring - Won’t Disarm | 19 | 1380 | March 14, 2024 | |
Disarm home monitoring system without code | 5 | 1479 | May 7, 2021 | |
Wyze app showed disarmed when Home was set | 3 | 653 | November 15, 2021 | |
Wyze home settings not working | 38 | 825 | September 3, 2024 |
