When will we be able to create a rule for home monitoring based on location or api?
Hey, you should be able to create a rule with a “Location Trigger”. Is that what your meaning?
If not check out the #wishlist to suggest an addition!
You can for non home monitoring, but in the home monitoring rules thsts not an option.
Oh, yea #wishlist is your best bet, just make sure it’s not a duplicate post ![]()
