Unless someone can help me solve the problem of the base unit constantly beeping whenever I change modes I’m going to have to send this thing back. I’ve had it in test mode since I installed it I don’t want to move it over to armed until get this beeping under control. My neighbors won’t stand for it.
I can’t stand the long and unnecessary beep when I change mode despite 45 seconds Entry/Exit delays. Just the “your system is arming” is enough. @WyzeRyan when is the next release/update for HMS? I have seen a lot of feedbacks here that needs to be addressed asap
I agree! Below is a Wishlist item; you may like to add your vote.
Looks like Wyze HMS was updated from the backend. Did anyone notice the long beep after you arm HMS is gone? I didn’t change anything. I tried it over and over. No long beep.
That isn’t my experience. Still beeping.
What firmware version is your hub because unless you have something different then everyone else the constant beeping is still a thing.
Sorry, I take that back. The issue is still there.
How could your neighbors hear it ?
I have my hub volume set on low, it’s in the den with the door shut and I can’t even hear it.
Maybe you don’t know that in hub settings you can turn the volume down to low
