HELP! Frustrated & Tearing My Hair Out: Wyze Pan Cam v3 Won't Connect or Won't Stay Connected
I’m glad you solved the issue. always here to help in any way I can.
I finally found a workaround that seems to be solving the issue.
Set up a guest network on your wifi router and only put the WCPv3 on that network.
My steps:
  1. Power cycle the WCPv3
  2. Delete the camera through app
  3. Setup again under the new guest network
Note: I also bound the IP and MAC address to my WCPv3 but I’m uncertain if this had any effect on the issue.
Do you recall the make & model of the cable you used?
Yes - https://www.amazon.com/gp/product/B0BPC7DZM1/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
There are different configurations depending on your need.
