Gun Safe - App Lock Code
I’d like to see more numbers other than 1, 2, 3, and 4 to use as the App Lock Code.
[Mod Note]: Your topic and all replies were moved from wishlist to the Home category as your request is satisfied by existing functionality.
There’s over 5,000 different options you can use with the four numbers. Although more is better,
from a material standpoint and being that the company doesn’t manufacture themselves their own products this may be prohibitive based on that. But it’s definitely worth a wish list topic to see if it could be done.
I’m not talking about the code I enter into the safe. I’m talking about the app and if I had more number choices then it would be easier to remember.
Oh okay, thank you for the clarification there.
That one would definitely be doable I think
I moved your request out of Wishlist. What app version are you running? I checked current production and beta on iOS and Android. Both allow up to 8 digits from 0-9:
My mistake, you are correct. Funny how it didn’t allow me to use other numbers when I first set it up.
That is strange. The only things I can think of that might preclude 0-9 are bug in non-standard keyboard selection or an obscure Wyze app bug.
