There should be a more current version of the beta available to you. Have you checked recently? You may find just what you’re asking for. ![]()
Hey…i am using version 2.2.19
Thanks.
Regards,Patrick
Please see my reply to gemniii. (Just a tip… If you reply via email, you may not see other useful information posted in a thread.) ![]()
How do I check?
I just loaded this last weekend.
If you’re on Android, it should be listed as an update on the Google Play store. For iOS, I’m not sure.
Where is it listed as an update?
/edit - per instructions I go to the Wyze app, click on “Account” then search for “About” -
it’s not there.
“https://support.wyzecam.com/hc/en-us/articles/360019706572-Keeping-Your-Camera-Up-To-Date”
/edit 2
Ah, I see your edit adding Google Play Store.
That worked.
Still not seeing the camera name in the feed.
After you open the group there should now be a gear icon at the top-right.
I’m was looking for a camera name in the feed, like the time stamp. Going to settings and “show camera name” was not obvious.
Is there some documentation where this is all spelled out?
/edit - I mean where all the updates are detailed
Ok thanks…i was at work and too lazy to open the full thread to respond, I will check your answer…Thanks !!
Regards,Patrick
They don’t put beta documentation on the support pages, only publicly released. That’s why the beta forum and FB group exist. I will try again to ask the Wyze devs about having more information available for beta releases in both those places.
I’m speculating you did find the setting, though?
Yes, found the settings.
I’ll note here that past “beta” groups I’ve been involved in required NDA’s and had a lot more info disseminated with the software.
Instead of the group feature i would like it to be different. When you start up the wyzeapp i want the tiles to fill the screen in rows of 3 or 4 and all on live and every tile should have a microphone so you can talk without going to the specific camera what takes time, and for sound 1 tap on a tile and if you want to enlarge an specific cam you do a double tap.
Hi
Love the grouping frature but you should bring back the option to select the individual cam via expanding the group. Now we have open the group and start streaming all the cams in the group before selecting one.
Keep up the great work!!
You can vote for that here:
Be sure to click the VOTE button at the top.
I am hoping that we can also group the motion sensors and also the Wyze sense door or window sensors. We can currently group our cameras but not the other projects.
Thanks
Since you are posting under Beta - We can Group
Cameras
OR
Contact Sensors
OR
Motion Sensors
But not a combination of sensors. Did you want a mix of cameras and sensors in one group?
What version of the app and what OS?
I don’t get a view like that at all.
