I would like to be able to check battery status of my cameras some other way(s) besides the app so I can programmatically do my own alerting. I do get notified at 20%, but would want to instead get alerted at 5%. 20% is still to early to get notified, and that doesn’t seem to be a configurable option.
Make sure you add your vote as the system does not automatically add it for you
Wyze has an api, but it’s not publicly documented. Some have reverse engineered it and there are some open source projects on GitHub from the community. I’m not sure if battery percent is an option, but you could check.
I don’t think Wyze intends on having an official api, they are focusing on supporting the matter standard instead.
