I installed a senser on my garage door. It works fine, but is there a way I can reverse the words in the Wyze app? I would like it to read “open” when the door is open and “closed” when the door is closed. Instead of when the senser is open or closed.
Shouldn’t it be the same thing?
Is the sensor closed when your garage door is open?
Sounds like you placed the contact sensor when the door was open. Youll have have to take it down and close your garage door and then place the contact sensors. So they read correctly.
If the help you received did not solve your issue and you still want open/closed reversed there is a Wishlist item for this currently. I have linked it below and you can head over and place your vote in the upper left.
