Garage door controller pin code
When I try to open my garage door through Google home and my voice it asks for a pin code and I can’t find where I set that up where I change it or where I can find it
With Google, you would set that up in the app. Unfortunately, mine is not hooked up at this time, but I recall, you go to the Camera you have the Garage Door Attached to, go to settings, then accessories and select the Garage door opener. The PIN is located there, I believe.
@carverofchoice @R.Good
Can either of you verify the actual location?
EDIT
@dankafka , I found this in the Forums. These are the steps
