Game cam use?
I would like to put a Wyse camera out in my pasture to watch wildlife. I have a wireless network that reaches out into the pasture - but not electricity.
Is there a battery powered option for a camera that is REALLY outdoors (totally in the weather) that would be appropriate for what I am trying to do?
All of the current battery cams (battery cam pro, solar cam pan, etc) are outdoor rated.
I’ve done this with a Battery Cam Pro with the add on Solar Panel, as well as with the new Solar Cam Pan.
I like both models, but the jury is out on which one I like better.
I had two Battery Cam Pro’s with the Solar panels watching the field behind my house, and got some great footage of coyotes and deer.
I don’t recall why, but I moved those somewhere else on my property, then after seeing a mountain lion on one of my Battery Cam Pro’s (and my neighbor saying he got some footage of two Mountain lions down in the field (where my two Battery Cam Pro’s used to be), I took that as ‘justification’ to purchase two of the Solar Cam Pan’s, and they now are monitoring the field if the two Mountain Lions return (so far they have not).
So far, both models have maintained a full charge on their respective batteries via the solar panels.
One complaint I have with the Battery Cam Pro’s is they will miss the ‘beginning’ of recording an event, as seen here:
This footage from one of my Solar Pan Cam’s explaining why these need to track wildlife, like they track people. Notice the camera doesn’t start recording until the Coyote is in the middle of the view of the camera. Almost like he ‘beamed’ in.
@TexasFig One thing worth planning for in a pasture is false triggers. Tall grass and branches moving in the wind can set off motion over and over, and that’s what drains a battery cam fastest, even with a solar panel. Aim it so there’s no vegetation right in front of the lens, start with the sensitivity a bit lower, and keep the panel facing south with open sky. Since your Wi-Fi is stretched out there, check the signal at the exact spot before you mount it. A weak link also eats battery because the camera works harder to upload each clip.
I’ve used Solar Cam Pan and Solar Cam outdoors, and they’ve continued to perform through some adverse weather conditions. Solar Cam is newer, so I haven’t had it exposed to as much variety, but it’s endured some hail storms without apparent incident. Solar Cam Pan I’ve had longer and has weathered that in addition to snow and hot summers. I don’t have any experience with Battery Cam Pro.
I get that - I plan on turning off all of the notifications on this camera. I’ll just look at the previous events.
