For Those Who Can 3D Print
That’s a nice design I like it :+1:, I suggest you Get a Forstner Drill Bit for the 1" hole in door casing, Wrap some blue tape around it At the depth you want ,a Forstner Bit will give you a nice clean hole and the tape Will show you when you’re at the depth you need to be .
This is what I have on a couple of doors in the door edge , They are Quarter inch long by Quarter inch diameter rod Magnets , I ordered some more for the other doors I have .
Pic is a steel skinned door
The ender-3 printer I got for about $180, and I love it.
Add a raspberry pi for octopi software so you can use it remotely if you like.
I printed some outdoor sensor covers and they’re working great.
Why are the links not working? Tried Chrome, Firefox, and Safara, all failed.
FWIW here’s my version for an outdoor mount and cover for the Wyze Sense contact sensors…
Thingiverse link, Wyze Sense outdoor mount and cover…
one of these days, I’m going to make a lens mount for my wyze cam that i have behind glass, so that I can thread a CPL filter onto it to get rid of the annoying reflections… but have to design it first…
Brilliant!
Thanks!! I really tried hard… Oh… Wait… You were talking to that other guy…
Nevermind
Anyone looking for a new project?
Wyze Sense light switch
Outstanding design! I will definitely try this out.
Newest design for a button
This could really benefit from a better printer then mine or maybe some injection molding.
here is a new print of the recessed bracket
Just made another one that people might like
I’m always impressed with your stuff. The low-tech water sensor hack is particularly inspired! Haha.
I love the idea! It’s just that it’s so permanent. I’m afraid of that level of commitment just yet.
It shouldn’t be permanent at all. The sensor is just sitting in the bracket. If for example Wyze makes and official water sensor you can simply slide it out and use it for something else. Maybe my deadbolt sensor :wink:
I am trying to make all my designs simple for the user with no need for soldering or anything technical. Also I don’t want to destroy any of the sensors so they would be able to be repurposed.
Yeah, I don’t see how it’s “permanent” really :slight_smile:
I’ve bought from @lachlan6 and I highly recommend him. He’s quick and the product was very good quality. I’d buy from him again.
I didn’t mean your design is permanent. Drilling the holes in the door frame is what I was referring to. Your design however is very clean and out of sight when installed!
