Flying international
My Wyze band is the only device that I am packing that I am not sure of. Will I need a power converter for Europe?
This thread should be helpful. Have a great trip!
Huh. I have the band and the usb clip it came with. Not sure what your talking about,
Check your Wyze power adapter to see if it says “Input: 100-240 volts”.
I have no such plug, wyze only shipped a Clip attached to a short usb cable.
Can I use an Apple plug with same specs?
It would be helpful to know which countries you will be visiting, but you probably want at least one of these.
