Floor Lamp head detached from base
On the Floor Lamp, the head became loose from the base. The connecting part on the head stripped and would no longer hold.
I installed a small hose clamp to hold the head in place.
Does this hack hold up? I have 2 and the hoods just dangle from the stripped area that you mentioned. Ugh so annoying. Of course this happens after the warranty expires. Love the lights when I could use them.
Great idea but a bit ugly though. Maybe super glue?
I wonder if a black zip tie would work and look better?
The zip tie would need to be wide to work, I’ll check at HD and see what they have as it would look much better than a silver fitting.
