Just received the Floorlamp and the head (socket and bulb) are covered with printing. “Safety” info and whatnot, kind of screws up the vibe of a pretty cool design. Has anyone tried to remove this?
@Customer… The safety info is not a sticker, label or tag… it’s printed onto the lamp and bulb assembly. The text is subdued, but definitely visible if you look for it. Other than sanding (not recommended), I don’t see how it can be removed. I tried the usual remedies to no avail… isopropyl alcohol, WD-40, etc.
