Floodlight v2 disconnects after few hours and only reconnects after turning it off for 30s or so
Our Floodlight v2 disconnects after few hours and only reconnects after turning it off for 30s or so and back on. WiFi router 3 meters away (802.11ax att fiber in the garage). Tried factory reset, power cycle and latest firmware, also the beta but did not solve the issue.
Is the firmware file available for floodlight v2?
Changed to a different access point model and now it stays connected. Also WiFi 6 Look like a bug…
WiFi6 isn’t in floodlight V2 specifications.
I mean both access points are wifi6, and backward compatible to 11n which the floodlight v2 supports. But with one of them it constantly disconnects.
Floodlight V2 does not support WiFi6, Some other issue is causing your problems, but definitely not WiFi6,
I’m having the same issue. When you say you changed to a different access point what exactly do you mean by this? Thanks
I just used another brand access point (tplink) that I had around instead of the att access point I was using before. I didn’t expect it to work with the other router but it did. I didn’t even have to power cycle the camera, it came back online on the new router (same SSID and password) after a few mins. In the future I would just buy one of the Wyze WiFi routers since this issue seem to be router specific and they for sure would test their own router with the cameras.
I’m having the same disconnecting issues, and I have an att router. I’ll try and old one I have to see if the that helps. Thank you!
I took an old linksys router, and plugged it into my att router. I configured, the camera to connect to the linksys router, and I haven’t had any disconnects!
I wish I knew what setting to fix in the att router, but this solution seems to be working for now. Note, I had already tried configuring the att router to use 2.4 Ghz only, that didn’t help.
