Just installed the floodlight pro. My old floodlight was turned on and off with a switch. I’m assuming I’ll have to leave the switch on for the camera that function. Is there a way to turn on the floods with the app? Thanks!
Welcome @razor3367
You can use the app to Turn the Flood light on. Live Stream the camera and tap on the flood light.
The Image shows the Flood Light to tap on
Thanks very much! I had it figured out. Just have to put a lock on the switch inside and get the wife to download the app so she can turn it on and off. ![]()
Since it is an IoT Smart Light, you can also turn the light on and off with other trigger devices like a Smart Switch, Smart Button, or Smart Plug using Wyze Rules and Alexa Routines.
