I just installed my new Floodlight Pro and everything is working great in the Wyze app. Additionally, I can see the camera feed in my Google home app, which is great. However, I cannot control the light with Google home app or assistant commands. Is there something I’m missing as far as setup/configuration that I need to turn on separately? There’s a picture on the product page that specifically shows Google home being used to turn on the light via voice command, so it would be pretty horribly dishonest if this is not an available feature.
I can’t find a way to control the lights from Alexa either. This was one of the main reasons I bought this light.
I have not been successful in finding Routine actions for the Floodlight Pro in Google Home.
In Alexa, so long as you have the Wyze Skill enabled and all the cams on your Wyze Account have been integrated as Devices within Alexa, the Alexa Voice Command for her to action the Floodlights is " Alexa, Turn the {Cam Name} On (or off). Alexa has no action ability to power the actual cam on or off, so using this command will only action the lights.
When building a Routine to action the lights, the Floodlight Pro cam will be listed in the Cameras section (the only ones I have found to have Alexa Routines Actions):
Once selected, you can control On\Off as well as brightness or some other lighting options.
