Female mini usb to female 2.0 usb adapter
Just got two 13’ wyze extension cords but male mini usb cables won’t join . Is there an adapter female mini usb to female usb?
Search amazon, you should be able to find a coupler. But it would be better to just get the length of cable you need with the correct ends, the more junctions you have, the more potential for problems.
Thanks. I was thinking the same thing. I’ll order a longer cable.
