Can you add the ability to select multiple cameras to view the alert notifications? For example, if I only want to look at the notifications for 2 of the 4 cameras. There should be a checkbox wheth you can check only certain cameras to view alerts. Currently, you can only select all cameras or a single camera.
Also, it should automatically save your previous selected cameras for alert notifications after exiting the app. That would be more convenient.
