I know @spamoni and possibly others are using POE setups to power their cams.
Happened to come across this Ubiquiti POE to 5v/2A USB adapter for $19. There are other cheaper ones out there, but this one is nice and compact and from a reputable brand.
This can power a single pan cam or two 1A non-pan cams using a USB splitter. As long as the two cams are within about 30 feet of each other, you can use two 15’ USB cables to power them from this. Or if closer, obviously the stock cables are fine. Pretty much any ethernet run (even CAT5) should handle this fine since it is power only. Heck I wouldn’t be surprised if CAT3 phone cabling would do it.
If you do your own run you can get nice thin CAT5e cables, or even flat ones. Pre-terminated is easiest, but you can also buy bare solid conductor cable, and either crimp RJ45 connectors (for those that know how) or punch keystone jacks onto it (much easier for novice users).
Only 4 pins are needed so a single run could handle two of these adapters, just make sure to get the pinout right.
As far as the AC power side, if you just need a single POE source, Ubiquiti also makes a couple cheap ones.
U-POE which is passive 48V POE and NOT AF compliant. I do not know if this will work with the above adapter. Some AF devices will accept passive 48V fine, others will not. But it is only $8, might be worth a try.
But the U-POE+ is AT/AF compliant and definitely will work with it. That one is $15.
If you want to do multiple runs, there are multiport POE injectors out there that are less than $15 per port (most are even less than $8 per port). Just make sure it is AF compliant and not passive (unless someone can confirm that passive works).
Of course if you have a POE ethernet switch you can use that, but usually those ports are going to be more expensive and it is sort of a waste, unless you have no other use for them.
Note none of these adapters are outdoor rated so you’d want to mount them inside and run the USB outside, or mount them in a weatherproof box.
