Factory Reset From RTSP
Hey All,
Was curious if doing the standard factory reset would work and allow me to update the firmware back to the original firmware and not the RTSP support? I just want to go back to the normal way the cam was when purchased.
Thanks,
Jace
@Jace You should be able to manually flash firmware on your cam to revert back. Follow the steps in the support articles. Download Firmware
