Extending Wyze Sense range by soldering on more antennae wire
Hi there, opening up a motion sensor, i can see the aerial on the top edge (similar to the below ) .
scratching the end of the pcb track gives you a surface to solder on, adding some wire i got the bridge to connect from 20m away
does anyone know what frequency this uses? what length of antennae wire is the practical maximum? thanks
ant|172x102
I have no personal knowledge about this topic, but it has been discussed over here: Wyze sense / bridge range - #45 by Solardave
Hopefully that helps you.
Closing this topic. Discussion can be continued in thread @nerdland referenced. :slight_smile:
