Excluding areas the can sees
Need to exclude a certain area in the camera’s view so it doesn’t trigger a false notification. Like a flag blowing in the wind.
Welcome @mercmarquis
To exclude an area, go to the Live Stream of the Camera, tap on the Gear at the Top Right to enter settings, then tap on Detection Settings. In there you should see Detection Zone, tap on that and the make sure all of the squares are on (you can see the image and it is not dark), then tap the squares to hide the area you would like.
