Events not showing in app for battery cams
So, I’ve been trying to figure out why my battery powered cams aren’t showing events. I finally went to https://my.wyze.com/events and they are there.
Any idea why they don’t show in the app? Wired cams work fine.
How are you trying to view events? Is it possible that you have a filter set for the app’s  Events tab that’s keeping them out of the list? If you navigate directly to your Cam’s Live Stream screen, do you see events listed there?
[I messed up. Replacing last comment.]
Was opening each cam (no filter there). Just checked events tab and they are there.
Do the battery cams not show events under the individual cam views? That’s confusing. I thought they finally added that feature request to all of them.
I don’t own any of the older Cam Outdoors or Battery Cam Pro, so I have no idea about those, though I’d expect the Cam Outdoors to be using an older UI unless Wyze has changed something recently in the app. My only battery-powered Wyze Cams at present are Battery Video Doorbell and Solar Cam Pan, and those both show events on each Cam’s Live Stream screen.
:+1:
Correct, they do not show up under individual cams like the plug in cams. I have four WCO v1 battery cams and all events are on the events page.
They are Outdoor Cam V2.
Oh well. Thanks.
I wondered about that and considered ‍@mentioning you for this. Thanks for the reply! :+1:
