Event recording schedule per daily basis + hours
Hi
After using the both cams for a couple of weeks it would be useful if I could tell the camera which days should record and not just the hours as it currently has.
For example I don’t need recording on the weekends because mostly I am home. Right now if I don’t forget I turn off the cam manually but then I need to remember to turn it back on Monday morning.
Thank you
Hi @sannyo,
This is already possible and is set up using the Shortcuts feature of the app. You set up a shortcut trigger for each on/off day/time combination. For example: Friday 5pm: OFF, Monday 6am: ON, etc.
Click the Support link top right and search for “shortcuts” for instructions.
Wow! Thank you! I was not expecting that to be there.
Went and set it up!
