Error Message on App - Resolved
Problem solved! Had to uninstall and reinstall.
am getting the attached error (device not registered) when I try to look at my cams. I can still click on it and view my cams. I checked all my settings, logged in/out etc. My subscription is still active. Any recommendations?
Wyze - Business as usual. I wonder if today’s app hotfix also came with a backend change, and caused this outage?
Android app 3.3.5.623 (not the hot fix)
Cams on Favorites tab: Failed to Connect | Error Code -00000
Can tap through to connected cam like @hwnatheart
Cams on Device tab: On
Some of the cameras are still functioning. But not floodlights V2 and pro.
Edit - seems to be coming back up now.
Huh. My cams are v2 & v3.
I just now pulled-down to refresh the Favorites tab and the cams loaded.
Closed and reopened app. All good.
Nighty night. :sleeping:
I haven’t noticed any issues.
I haven’t seen the hotfix available.
I feel I must assert this once again (and not just to be contrary! :grin:)
Given the timing and description of the problem, I suspect this may have been related to Favorites screen not working.
Welcome to the Forum, @hwnatheart! :wave:
Could be they were working on “usability improvements” in the background and had to disconnect “it” briefly to achieve “it.” :slight_smile:
