error code 0
I just purchased the Wyze cam and absolutely loved it and simple set up. Huge problem… my live streaming does not work at ALL!! I have WiFi at work and my live feed won’t even connect to the camera and than throws a code error 0. I tried resetting it and nothing worked. But as soon as I am at home and hooked into our WiFi it works great. Did an experiment and turned off my WiFi in the same spot and lost signal and no video!! What can I do???
I am having the same issue from work as well. I try to connect to the live feed through the app but keep getting (error code 0). Any suggestions?
There is a thread already open on this. The link is below. I hope this helps. :slightly_smiling_face:
